24.06.2013, 10:58 | #1121 | |
Регион: 38
Машина: Camry 2003 ACV-31
df -h mount
Как я ставил Nexus 7 в машину http://amurchick.ru/carpc/ |
24.06.2013, 12:09 | #1122 |
[QUOTE=AMurchick;262139]Пришлите вывод команд (запускать в эмуляторе терминала):
df -h mount[/QUOT u0_a42@android:/ $ export PATH=/data/local/bin:$PATH u0_a42@android:/ $ df -h Filesystem Size Used Free Blksize -h: No such file or directory 1|u0_a42@android:/ $ mount rootfs / rootfs ro,relatime 0 0 tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0 devpts /dev/pts devpts rw,relatime,mode=600 0 0 none /dev/cpuctl cgroup rw,relatime,cpu 0 0 proc /proc proc rw,relatime 0 0 sysfs /sys sysfs rw,relatime 0 0 debugfs /sys/kernel/debug debugfs rw,relatime 0 0 tmpfs /storage tmpfs rw,relatime,mode=050,gid=1028 0 0 tmpfs /storage/emulated tmpfs rw,nosuid,nodev,relatime,mode=050,gid=1028 0 0 none /acct cgroup rw,relatime,cpuacct 0 0 tmpfs /mnt/secure tmpfs rw,relatime,mode=700 0 0 tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0 /dev/block/dm-0 /mnt/asec/com.applay.overlay.pro-1 ext4 ro,dirsync,nosuid,nodev,noatime,user_xattr,acl,bar rier=1 0 0 /dev/block/dm-1 /mnt/asec/com.ss.launcher.to-1 ext4 ro,dirsync,nosuid,nodev,noatime,user_xattr,acl,bar rier=1 0 0 /dev/block/dm-2 /mnt/asec/com.cyphercove.audioglow-1 ext4 ro,dirsync,nosuid,nodev,noatime,user_xattr,acl,bar rier=1 0 0 tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0 tmpfs /mnt/fuse tmpfs rw,relatime,mode=775,gid=1000 0 0 /dev/block/platform/sdhci-tegra.3/by-name/APP /system ext4 ro,relatime,user_xattr,acl,barrier=1,data=ordered 0 0 /dev/block/platform/sdhci-tegra.3/by-name/CAC /cache ext4 rw,nosuid,nodev,noatime,errors=panic,user_xattr,ac l,barrier=1,nomblk_io_submit,data=ordered,discard 0 0 /dev/block/platform/sdhci-tegra.3/by-name/UDA /data ext4 rw,nosuid,nodev,noatime,errors=panic,user_xattr,ac l,barrier=1,nomblk_io_submit,data=ordered,discard 0 0 /dev/fuse /mnt/shell/emulated fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=102 3,default_permissions,allow_other 0 0 /dev/fuse /storage/emulated/0 fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=102 3,default_permissions,allow_other 0 0 /dev/fuse /storage/emulated/0/Android/obb fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=102 3,default_permissions,allow_other 0 0 /dev/fuse /storage/emulated/legacy fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=102 3,default_permissions,allow_other 0 0 /dev/fuse /storage/emulated/legacy/Android/obb fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=102 3,default_permissions,allow_other 0 0 u0_a42@android:/ $ |
24.06.2013, 12:17 | #1123 |
Регион: 38
Судя по выводу команды, у вас просто не смонтировался диск. Потому и папка пустая.
Попробуйте сначала запустить какой-нить софт, которым потом диск смотреть будете и только потом подключите usb-диск, так же проверьте - лампочка на диске моргает или нет после подключения диска.
24.06.2013, 15:04 | #1124 | |
24.06.2013, 15:28 | #1125 |
И ещё вопрос. Искал, но так и не нашёл. Можно как-нибудь заставить планшет колесиком мыши регулировать уровень громкости?
24.06.2013, 15:40 | #1126 |
Машина: Lexus RX350 '07 US
Копал в эту сторону, но никаких вариантов не нашел, взял USB клаву с крутилкой, распотрошил ее, припаял нормальный нажимной энкодер вместо крутилки клавы, установил в машину - теперь счастлив, с помощью таскер теперь можно хоть профили навешивать на нажатие/вращение.
24.06.2013, 17:09 | #1127 | |
Регион: 38
Код:
## Vold 2.0 fstab for cardhu ####################### ## Regular device mount ## ## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...> ## label - Label for the volume ## mount_point - Where the volume will be mounted ## part - Partition # (1 based), or 'auto' for first usable partition. ## <sysfs_path> - List of sysfs paths to source devices ###################### # Mounts the first usable partition of the specified device #dev_mount usbdisk /storage/usbdisk auto /devices/platform/tegra-ehci dev_mount usbdisk1 /sdcard/mnt/disk1 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.1 dev_mount usbdisk2 /sdcard/mnt/disk2 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.2 dev_mount usbdisk3 /sdcard/mnt/disk3 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.3 dev_mount usbdisk4 /sdcard/mnt/disk4 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.4 dev_mount usbdisk5 /sdcard/mnt/disk5 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.5 dev_mount usbdisk6 /sdcard/mnt/disk6 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.6 dev_mount usbdisk7 /sdcard/mnt/disk7 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.7 dev_mount usbdisk8 /sdcard/mnt/disk8 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.8 dev_mount usbdisk9 /sdcard/mnt/disk9 auto /devices/platform/tegra-ehci.0/usb2/2-1/2-1.9
24.06.2013, 18:12 | #1128 |
А отображение уровня громкости при регулировке можно сменить стандартное на какое нибудь другое?
25.06.2013, 00:02 | #1129 |
Ещё вопрос (а их у меня мнооогооо..)))). Имеется аудиоплеер jetaudio (со встроенным эквалайзером), и видеоплеер mx player(организовал с помощью проги overlay переход к настройкам эквалайзера Equalizer fx).Дык вот проблема в том, что при юзании эквалайзера в аудиоплеере и последующим переходом в видеоплеер и попытке запустить equalizer fx, он (equalizer fx) вылетает в ошибку. Запутанно как-то объяснил наверное. В общем вопрос, как у вас организована связка аудиоплеера и видеоплеера (очень интересует настройка эквалайзера при просиотре видео)?
25.06.2013, 04:23 | #1130 |
А какая тут может быть связка? То один плеер включаешь, то другой. Встроенный эквалайзер - зло, ИМХО. Советую выставить все в линейку.
android, nexus 7 |
Здесь присутствуют: 21 (пользователей: 0 , гостей: 21) | |
