Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > Road Runner > Скины для Роад Раннера
Старый 31.10.2007, 01:06   #1
MegaPon
Аватар для MegaPon
Машина: Mitsubishi L200 2007
MegaPon is a jewel in the roughMegaPon is a jewel in the roughMegaPon is a jewel in the rough
По умолчанию Опять CrystalBlue Beta
Люди выручайте кто силен в англицком и компах (во втором думаю что большенство)...
очень мне уж запал у душу этот скин но никак не могу поставить обновление на него...вот текст что нужно делать...
Hi,
this is a patch that let you see how the new skin will look like..
It's just a main menu replace, but with a lot of new features .
--------------------------------------HOW TO INSTALL-----------------------------------------------
o Make a backup of RoadRunner.exe
o Copy the RoadRunner.exe in the zip to the Road Runner folder
o Copy the GDIPlusWrapper.dll where you want (better in the Road Runner folder) and
register it with the command:
REGSVR32.EXE <path where you copy the dll>/GDIPlusWrapper.dll
o Change in skin.ini and EcexTBL.ini the path with Programmi with Program files if needed
o Open rr.ini and just add the line
FASTMODE=-1
o It's a skin preview so it's probable I forgot some file, so please report any bugs
I hope you like the easy installation, I worked a lot for it .
--------------------------------------FEATURES ADDED-----------------------------------------------
o First of all you can change the background changing the file reference in skin.ini.
You can find this new file in the skin folder and have to change the line:
BACKGROUND=...../imageyouwant.jpg [.png]
o On the top you can see the new display, you can choose the info displayed by pressing
the right and left arrows. Now there are just three info you can choose between, but
I'm working on it
o In the right corner on the top there's the minimize icon
o Holding the power icon pressed it jumps the exit menu end exit directly.
You can choose what to do when holdpress simply by pressing the power icon and then
holdpressing one mode in the exit menu. The skin will remember your choice and will do
the same thing when you'll holdpress power icon again.
o The menu is completely configurable. Now you can choose which button does what.
(I spent a lot of time on that feature so you MUST be happy about it )
You have just to holdpress the button which you want to change the function of, a menu
will appear where you can choose the new function. I know... I know... the menu is not
so good but it's for the meantime... after all it's a skin preview..
you remember it, don't you ??
то чно жуно заменить ехе файл на файл из архива я понял
то чно нужно прописать строку в rr.ini я понял
то что жуно заменить Programmi на програм файлс я понял...
про то чно нуцдно сделать с REGSVR32.EXE не понял нифига (((((...
вроде сделал все как надо в итоге вместо скина имеем вот это
что с тим делать не знаю помогите будте ДОБРЫ!!!!!!
вот линк на описание программы.... http://www.mp3car.com/vbulletin/rr-s...-released.html
Готовность 99%...
Проект: http://pccar.ru/showthread.php?t=1455
MegaPon вне форума   Ответить с цитированием
Старый 31.10.2007, 01:41   #2
archer
Аватар для archer
Машина: 2007\chery\Amulet
Примерно так:
- Скопируйте файло GDIPlusWrapper.dll куды захотите (но лучше в папку с РР) и зарегистрируйте его введя в командной строке:
REGSVR32.EXE <путь куда поклали этот файло>/GDIPlusWrapper.dll
А то что у тебя показывает похоже на то что бэкграунд не цепляется!
Старый 31.10.2007, 01:45   #3
archer
Аватар для archer
Да - если получится запустить - скинь сюда скриншетик с любой навигашкой плиз...
Старый 31.10.2007, 11:16   #4
MegaPon
Аватар для MegaPon
Примерно так:
про это я понял.... примерно так я и сделал...скопирвоал этой фай в дерикторию РР и скопировал тудаже REGSVR32.EXE создал батник со строкой вида
REGSVR32.EXE /GDIPlusWrapper.dll
... запустил...он пишет я так понял что нужно еще дописать команду что с этим файлом нужн осделать дописал так
REGSVR32.EXE /i /GDIPlusWrapper.dll
все одно реакции ноль как я понял поотмоу что ничего не изменилось...
потом вспомни что може я не поставил флеш плеер...поставил его версия помоему 33 или 32 не помню точно в итоге прога совсем не запускается...пипец....((((((((((((....выдает ошибку содержание типа что он не может запустить скин...
может кто сделает доброе дело опишет мою ошибку разработчику в соотв теме а то я в инглише не особо силен...
Готовность 99%...
Старый 31.10.2007, 11:18   #5
MegaPon
Аватар для MegaPon
а кста по поводу навигашки вроде как в старой версии выглядела она как стандартный скин BMV2...в новой на скоко я понял он это переделал ну запустить как сам понимаешь я не могу чтоб посмореть...
а и еще у него скин заточен под несколько навигашек...
Map Monkey
nRoute
iGuidance
и может я туплю но в последней версии скина видел файлы под Дестинатор...
вот так...
Готовность 99%...
Последний раз редактировалось MegaPon; 31.10.2007 в 11:54.
Старый 31.10.2007, 11:45   #6
terracan
Аватар для terracan
Машина: Terracan
Зачетный скин.
Старый 31.10.2007, 11:51   #7
MegaPon
Аватар для MegaPon
вот и я про тоже токо вот до ума его довести бы....
ничего не посоветуешь?!
Готовность 99%...
Старый 31.10.2007, 11:56   #8
terracan
Аватар для terracan
Машина: Terracan
будет время попробую, поставлю.
ты тож не вешай нос и о результатах докладывай.
Старый 31.10.2007, 12:03   #9
MegaPon
Аватар для MegaPon
да докладываю.....еще здесь http://pccar.ru/showthread.php?t=3458 начал...
я думаю что если так пойдет нада все в одну ветку объединить...
попробуй если не сложно встанет он или нет у тебя...
Готовность 99%...
Старый 31.10.2007, 12:47   #10
terracan
Аватар для terracan
Машина: Terracan
встал, без всяких бубнов
Часовой пояс GMT +4, время: 20:30.
